Updates to Mounting Accessories in Konnected Kits
As we transition Konnected from a Kickstarter pre-order product to retail, we're looking for ways to refine the product and streamline the installation and setup process. As a result of this, we're making a small change to Konnected Alarm Panel kits today:
All Konnected Alarm Panel kits will now include adhesive backed standoffs for mounting instead of the blue acrylic mounting panel and tape. The blue plexiglass board is now available separately for just a few dollars extra.
There are several reasons for this change, but mainly we're striving to make mounting your Konnected gear simpler and safer. We've received feedback from early Kickstarter backers that the mounting tape didn't always stick well, that it was difficult or too much work to drill holes in the mounting board, or that it was hard to arrange multiple Konnected devices on the plexiglass board.
These adhesive backed standoffs fit perfectly in the mounting holes on the Konnected circuit board and have a very sticky adhesive backing that works great on metal, plastic, wood, drywall or almost any surface. The standoffs suspend the Konnected circuit board from the mounting surface, ensuring optimal airflow and heat dissipation, and preventing short circuits by accidental contact.
The standoffs are also more readily available for us to source in volume, and they simplify our fulfillment processes.
For those of you that still want the attractive look of the glossy blue plexiglass panel, it's available as a $5 add-on here.
We also offer magnetic standoffs as an add-on upgrade for those that are mounting in a metal cabinet and want a removable and reposition-able mounting solution.
We're transitioning to this new kit assortment beginning May 30.
4 comments
I have a bunch of cables (each with two wires) coming out of a closet. Not marked. I suspect a commercial alarm was installed but removed during a foreclosure. I have found some door sensors. However I can see no wires or window sensors. Windows about 12 yrs old. Window frames not metal. Flush metal tabs about 3 inches above vertical sliding window. 1 inch long in track. If those are intended to be part of an alarm system, how do I tell? If I take a chance and buy your board will it tell me?
Ed Burckhardt •
Hi Sir,
This is Sharon from Reliable Mould company sincerely writing here ,a professional injection mould ; Die casting ; CNC machining and 3D Printing factory located in Guangdong.
50% Lower cost
200% better quality
Fast delivery
Perfect service
Pls kindly send RFQ details for better pricing if any enquiries.
Thanks so much and sorry for bothering if any .
Yours sincerely
Sharon
Reliable Mold Co.,Ltd
Mobil:+86 186 8106 6512 Tel: 86 -769 21611535 Fax: 86 769 21611536
Email:Sharon@reliablemold.com
Web: http://www.reliablemold.com
Lotus Square Industry Zone 523800, Changan Town, Dongguan City, Guangdong,China
sharon •
I have a DCS alarm system which is still active/full functional and professionally monitored. I was wondering whether your Konnected panel can be added in parallel, so as to add Smart Monitoring while maintaining my professional monitoring. All this to say, I do not want to replace professional monitoring for self-monitoirng; I want to be able to do both.
Thank you.
Caleb
CALEB BOUHAIRIE •
If I bought the Adhesive mounts already will that price be refunded when you send my kit?
Mark Fundakowski •
